September 19, 20205 yr Good day. H I have 8 4.8kw 100amp lithium sun pays batteries with 3 axpert inverters installed. Is there a way to balance or equalize the batteries? The inveter does not communicate with the batteries and icc does not yet have software for the communication between the inverter and batteries. Where can I find communication cables for the batteries as they did not supply me with the cables and will the batteries communicate when I install the cables to balance and equalize with the BMS software on the batteries? Thank you
May 16, 20215 yr On 2020/09/19 at 10:25 AM, Leosol said: Good day. H I have 8 4.8kw 100amp lithium sun pays batteries with 3 axpert inverters installed. Is there a way to balance or equalize the batteries? The inveter does not communicate with the batteries and icc does not yet have software for the communication between the inverter and batteries. Where can I find communication cables for the batteries as they did not supply me with the cables and will the batteries communicate when I install the cables to balance and equalize with the BMS software on the batteries? Thank you You can get a cable from TheSunPays, they also have software to monitor it called TSPSolarBot
May 16, 20215 yr On 2020/11/02 at 3:10 PM, Faan said: What are the safe settings on Float charge for these 4,8 sun pay batteries. Setting 26 : 51.6v Setting 27 : 51.5v Check TheSunPyas site under the batteries, there is a guide on what settings to use
