Goodwe 5048 ES / Pylontech - Lightning Strike: Charging but not Discharging
Hi!
I had a relatively close lightning strike this weekend, I lost some network equipment and a 3d printer.
My Inverter (Goodwe 5048ES) at first glance survived. It charged the batteries fine from the solar panels the day after:
But this graph shows the issue: I'm not getting anything out of the batteries since the strike at 20:30.
Looking at pv master's alarms I get this (sometimes?):
  1. "Discharge current limited by bms is low" sounds like what I am experiencing.
  2. SelfUseOff - No idea why I'd be getting this, my mode is set to general/normal. I don't even know where to set the times. When I go back to basic setup and set mode to normal again the alarms are seemingly reset. Maybe I'll get this again after it ran for 24 hours and it made a realization...
  3. SOC Delta OverRange - That doesn't sound good.
Here is the parameters info from PV Master:
The CT meter tests says it is connected correctly.
I shut down my batteries and started them up again. I guess I should do the same with the inverter, I thought if it can charge it can discharge ...
Any ideas ?
Thanks!
Edited by Reyn
Title
  • Sadwe changed the title to Goodwe 5048 ES / Pylontech - Lightning Strike: Charging but not Discharging
