Mecer Lobo inverter
Greetings
At the rear of the inverter, there is a round button marked as circuit breaker.
It seems to be pushed in, which makes me think it's "tripped". How do I reset it, unscrew it?
Google isn't very forthcoming.
Many thanks
I don't know that particular inverter but all the circuit breakers I know of that look like that pop out when they trip and you push them back in to reset them.
Thank you, to me it isn't popped out, so this being reset?
The unit is in fault mode. I have removed the battery leads as well as disconnected the mains power.
Yes, if it isn't popped out then the circuit breaker has probably not tripped. This means that your problem must be elsewhere.
Unfortunately I can't really help since I don't know much about that particular inverter, but I'm sure there are others on the forum who can give you some advice.
