December 28, 20205 yr HI hellooo.. I have 8x 3000 pylon batteries and 3x Axpert 5KvA which I used to control through ICC on Pi, and now I got a LV-Hub for various reasons. I got the batteries on 2 groups of 4 connected to the LV-Hub, but I don't know how to connect the hub to the Pi?? I used to connect to the batteries through the console port, but can't do that with the hub obviously. Has anybody done this, that can give advice? Thank you in advance... :)
March 13, 20215 yr Did you ever get a solution to this? Do I need th LV-HUB? I have 1 bank with 4 us3000c in them. And one new Bank of 4 just arrived, but not installed yet Problem is that cables are rated to 120A that feed the Breakers / isolaters First bank feeding the breakers / isolaters Do I need to set my second bank also direct to Breakers to avoid an overload of 120A on the long cables to the breakers and short ones between the 4 batteries. Then how would ICC communicate to the second set of batteries as the Pylontech cable is connected to the first bank console port?
