May 21, 20215 yr Flexible panels are so expensive. Normal panel between the 2 roof rails (with custom rail bars). What do you guys think? Prone to break? Do you think there will be small structural movement that may crack panel? It will be permanent mount (to lazy to remove it between trips) Do not want to glue things to the roof.
