Inverter Battery combination not working
I recently installed a Kodak H4.6 inverter with 2 x Kodak fl5.2 batteries - 12 x 340W pannels.
The inverter had to be updated to the new firmware for the inverter to work with the battery - I had to use FOX batteries as set and not the KODAK as per installer instruction. The second battery as slave is not working at all and apparently also needs a firmware update.
My other issue is that the inverter is not charger the battery when there is capacity on the pannels - only if I pick storage mode BACKUP with SOC at 100% does it charge up to full. Any idea what I am doing wrong with both inverter of battery setting not working with second battery?
