June 6, 20215 yr Hi, About two years ago I bought a 12V 160W Ecoboxx battery system that can be charged from a solar panel or an AC 'switching power supply'. I use it to power my router and some DC lights (supplied with the Ecoboxx) during load shedding. The AC charger has stopped working and I would like to replace it, however I'm having trouble matching the specifications on the charger to actual products that I can find online. The charger output is printed as 16V, 2A on its sticker (see attached images). I have not been able to find such a charger. 15V, 2A chargers seem to be pretty common though. Would such a charger work with my Ecoboxx? Thanks
June 29, 20215 yr A universal laptop charger should work, you can get them from most electronic stores for R200. Get the adjustable ones where you can set the output voltage. 16v 2A is fairly common
