Mppt dc question
2 hours ago, Barryv said:
Hello
Are you winning with your solar setup?
Yes thank you. Getting a grasp on solar and electricity.
Only gripe right now is the MECER ivr 1200mppt inverter has both fans going full tilt 24/7 regardless of temp. And they ain't quiet that's for sure. Guess since it's a cheap inverter they cut back on costs such as temp sensor for fans.
Am going to swap out the fans for some good silent ones I found on Amazon.
In the meantime until they arrive I'm going to attach a resistor to the fans to lower their speed slightly, stepping them down from 12v to 8 v. We barely draw more than 250w and it's butt cold in our kitchen so I doubt those fans need to be on full blast all the time.
