November 8, 20169 yr My inverter just turn off dew to thunder struck and wasn't coming on again what can I do to make it work again.
November 8, 20169 yr Hi. Welcome. It can be anything to be honest. You will have to send it in to have checked.
November 9, 20169 yr 18 hours ago, Rafeal said: My inverter just turn off dew to thunder struck and wasn't coming on again what can I do to make it work again. What inverter do you have? Did you check the isolators, fuses (if you have some) and circuit breakers? Any noticeable damage? Does it smell burnt?
November 10, 20169 yr 8 hours ago, Rafeal said: Axpert inverter All the fuses are very ok likewise the breaker Can you test the voltage on the battery terminal, inside the inverter? And did you check the breaker on the bottom of the inverter? Does any lights come on with there's sun on the solar panels?
