Pv panel wire
Hi guys  I am new to Solar .
Busy getting all myvstuff ready
Need some advice  is iti compulsory to use only double insulated wire from panels to invertor. I do have good quality dc cable .but the 2 wires are togerther in the same sleeve. Multi strand 6mm sq .
Just afraid of magnetic field as a friend mentioned that it affects your invertor .
PV wire is rated for harsher environments, like being outside. It should also be UV resistant and have a flame retardant. In addition to that it is rated for higher voltages.
So to answer the question - do the right thing.
Another one if you could advise. All the Dc cable from panels to combiner box .must it be the same length
7 hours ago, 87 Dream said:
Not a requirement. You try to keep the cable as short as possible because of losses. But they dont need to be the same length.
87
Thanks just needed to confirm .really appreciated
Thanks Guys .Another Guy told me you have to get authorization from municipality to go solar even they could charge a Levy .Any truth in this .Cape Aghulas area .
