Instinct
I have a Axpert 5kv 48v inverter set up with 3strings of 405w PV panels connected in parallel(74v). System worked fine with 100ah  4,8kw lithium ion battery for a long time. Added same make 7800kw 150ah battery in parallel. System is running fine during day with sunshine but when no PV available unit switches over to utility (+-20sec ). After a while unit kicks back to battery? Settings as follows:
1.SbU
2.30A
3.APL
4.SdS
5.Use
6.LfE
7.trd
9.50hz
11.30A
12.49v
13.50v
16.OSO
18.default
19.default
20.default
22.default
23.byE
25.default
26.52,5v
27.51.8
29.47,6v
31.Sbe
Please could any body assist with the setup?? Tried various settings with no positive results. Need inverter to switch over to utility with no PV(after dark)
Regards
Instinct
