Lux power SNA setup
Good evening I need help with installer code on Lux power registration for my client, I put in the wrong customer code and could not see his unit on my account to make adjustments on it for parallel settings is it possible to change the customer code?
  • 8 months later...
Good day
I have a 5kw Lux Power inverter paired with a Dyeness A48100 4,8kWh Lithium - ion battery.
Unfortunately the battery does not communicate with the inverter, So we have been using it under "Lead-Acid".
for the last 3 weeks or so it appears that our battery parameter settings were set to default resulting in the battery completely dying and the house without power, When it should of switched over to the grid.
Yesterday I went through the Inverter settings using the luxpower monitor app, And for some reason my battery parameters were all reset to default (i.e Cut Off Voltage 42V, EOD Discharge Grid on 42V)
I was only able to set the EOD Discharge Grid On voltage using the app. When I tried to set the Discharge cut off voltage it would give me "Operation failed, Error code 3". Therefor I opted to set those two values directly on the inverter using the LCD Display.
This morning the battery cut out at about 2AM with 20% SOC Remaining, Indicating that the battery discharge cut off setting is working as it should however the End of Discharge Grid on setting is still not working despite the two settings being set to the same value of 47V according to the battery manual.
I have changed the EOD Grid on to 47.7V from 47V in hopes that it will take effect tonight.
Something to keep in mind is that In our 5 months of ownership we have not updated the inverters firmware
Please advise on solutions to solve this problem.
Kind Regards
Brian Zeelie
Edited by Bryan1
26 minutes ago, Bryan1 said:
Good day
Kind Regards
Brian Zeelie
hi Brian - just a privacy note to remove your cell number from the post - its a public forum and not everyone does the right things
Edited by mzezman
spelling
On 2022/11/18 at 9:04 AM, Bryan1 said:
Good day
Kind Regards
Brian Zeelie
Hi Bryan
did you manage to get this sorted? Dyness and Luxpower do definitely work together - just need to correct cable pinout and setting on the inverter itself
36 minutes ago, Bryan1 said:
Hi Mzezman Yes it was actually a blown AC breaker and after replacing it the system is working well again thanks.
Ah nice - good to hear. Many happy generation hours ahead
  • 9 months later...
  • 1 year later...
Hi Brian, did you solve your issue? As we have the same issue.
