April 20, 20224 yr I learnt through bitter experience that anything low cost is high risk. I am by-and-large an electronics ignoramus so maybe my lesson was not learnt properly yet - please help! So I have in mind a simple system that can run x2 PC's a few led's maybe a few other electronics. Max approx 175 watt draw. Must survive a load shed ie x 2 hours. I have in mind the following: 1. Blue Nova Energy - Lithium Iron Phosphate 13V - 44Ah -570Wh Battery 2 VICTRON PHOENIX INVERTER 12/375-230V VE. DIRECT SCHUKO 3. VICTRON BLUE SMART IP22 CHARGER 12/15 Will this fulfil my requirements? What else do I need? What is a Schuko? If anybody can help - please!
May 15, 20224 yr On 2022/04/20 at 9:52 AM, Clivevan said: I learnt through bitter experience that anything low cost is high risk. I am by-and-large an electronics ignoramus so maybe my lesson was not learnt properly yet - please help! So I have in mind a simple system that can run x2 PC's a few led's maybe a few other electronics. Max approx 175 watt draw. Must survive a load shed ie x 2 hours. I have in mind the following: 1. Blue Nova Energy - Lithium Iron Phosphate 13V - 44Ah -570Wh Battery 2 VICTRON PHOENIX INVERTER 12/375-230V VE. DIRECT SCHUKO 3. VICTRON BLUE SMART IP22 CHARGER 12/15 Will this fulfil my requirements? What else do I need? What is a Schuko? If anybody can help - please! Schuko is the round 2 pin plug as was fitted to power tools until recently. The standard in Europe.
