Victron Centaur battery charger - gone dead?
Hi there, we have a Victron Centaur battery charger (on a yacht). - model is 12/40  (ie. 12v 40A)
https://www.victronenergy.com/chargers/centaur-charger-12v-24v#downloads
There was a short in a connection and a bit of smoke came out of a plug. Plug has been replaced and there is 220v going into the system - this is shore power, comes from the mooring to charge everything when you're parked. It is very hard to work out the wiring exactly, but at least i know it has power.
This is a bulletproof looking device BUT not much in the way of diagnostics. I have got the manual now and all I can really see is that there might be an LED on/off. there is no on/off switch, the only way we can see it working is a current needle to show the amps drawing to charge batteries.
The problem is that it is a yacht, so getting to it is a mission of note, it's under a bunk so i can only really see the front panel. - i couldn't see if the LED was lit or not.
this is all the manual helps you with.
Now I don't see any fuses or circuit breakers on the device, and the recommendation of taking it to a dealer to replace a fuse is a little bit nanny state in my mind. Also, we're talking boat electronics so the experts charge like a wounded bull.
any experience with these, suggestions?
  • 2 years later...
Long term update.
This was fixed by finding obscure fuses that are wired onto the pcb.
It has now properly packed up, and no one wants to touch a 15yr old device. The boat can get a new one with Bluetooth and lifepo capability when that becomes a viable option.
Anyone want it for spares?
