April 30, 20224 yr Good day all, moving this topic from General to Solar... So I have the following: 3kv Axpert clone 24v 4x canadian solar 350watt panels Victron bmv-712 Victron battery balancer Raspberry pi running icc software Forget the batteries, I’ve gone through 4 of them because of wrong settings or float bug issues, all was agm batteries. So I’m looking at getting a pylontech, but the only 24v option is the up2500. Is this a good option, and then where do I start with the correct settings because of the float bug? I only need around 600w backup for max 4 hours. So, what is the best way to put all this together, or should I scrap the axpert clone and go 48v? If I use a pylontech, should I remove the Victron BMV? This is my Inverter - https://www.fullcirclesolar.co.za/product/3kva-vp-3000w-unit-vat-incl-copy/ Any advice welcome, Thanks! Dion Edited April 30, 20224 yr by dionvdberg
May 1, 20224 yr On 2022/04/30 at 7:46 PM, dionvdberg said: Good day all, moving this topic from General to Solar... So I have the following: 3kv Axpert clone 24v 4x canadian solar 350watt panels Victron bmv-712 Victron battery balancer Raspberry pi running icc software Forget the batteries, I’ve gone through 4 of them because of wrong settings or float bug issues, all was agm batteries. So I’m looking at getting a pylontech, but the only 24v option is the up2500. Is this a good option, and then where do I start with the correct settings because of the float bug? I only need around 600w backup for max 4 hours. So, what is the best way to put all this together, or should I scrap the axpert clone and go 48v? If I use a pylontech, should I remove the Victron BMV? The UP2500 can only provide 2550wh so it is very fine to supply your 2400wh load during the 4 hours. If your load is over 600W they will come short. The BMV can be handy to have but the battery balancer will not be of any use. Sorry to hear of the wrong setting on the AGM's.
May 2, 20224 yr Author Thanks for the info! Yeah according to everything I've read, the settings was correct, but I have a suspicion they were chronically undercharged (Float bug maybe?), both sets lasted me just over a year.. So I'm just trying to avoid losing a very expensive Lithium also.. Cheers Dion Edited May 2, 20224 yr by dionvdberg
