June 13, 20224 yr Hi there. I'm based in the UK and don't know if I should be asking on here but I can't get any information or help here. I have 10 X JA 545 panels, 5kw Sunsynk hybrid inverter and 5.12kw Sunsynk battery. It's set up to charge the battery from solar and use the battery when there isn't enough solar generation. I have noticed that every morning when the solar kicks in and starts to charge the battery, the grid import also gets higher. I know it has to have the 20w trickle in, which is annoying but I understand. But the grid import goes up to 200w for the length of the battery charge, it can be 1 hour or 4 hours depending on solar generation. When the battery is fully charged the grid then turns to export. Does anybody know why this happens? Many thanks
June 13, 20224 yr If you provide your settings and timer screens you will get help from other members. You can also search in the inverter section for other topics around this.
June 14, 20224 yr Author Please see the timer screens screenshots, what other setting should I show? Thanks
