Sunsynk Settings Help
I need help on settings as I am missing something obvious.   I want my system to be configure as follows but at the moment, I can’t get it to run off battery primarily when PV is not sufficient.
First source of power = Solar
Second source of power = Battery
Third source of power = Grid.
When the battery hits 20% SOC, then it returns to grid but only charges via Solar. Once it hits 40% SOC, then it returns to from Grid to Battery as secondary source of power.
This way of thinking comes from my previous Axpert Inverter where the load priority was set to SBU (Solar, Battery, Utility) and then via the ICC Software, I would control the 20%, and 40% thresholds as the Axpert relied on voltage settings for this.  I am hoping I can get a similar setup to this on the Sunsynk unless someone can suggest a better method?
Currently my battery and system settings are as follows (let me know if you want any more screen shots)
Managed to answer this myself with the use of the timer settings... Needed to re-read the manual with the inspiration of some You Tube videos too
