June 21, 20224 yr Good afternoon all I am new to this forum and to the inverter/solar discussions. I am in the process of purchasing an inverter. I have the following two options: Sunsynk 5kW Hybrid Inverter and Mecer Axpert King I want to be able to monitor my inverter via WIFI, Sunsynk comes with the functionality however Mecer not. Has anyone used Solar assistant successfully with Axpert? Appreciate your input Thanks
June 22, 20224 yr Author 1 minute ago, Jacques Ester said: Solar assistant works perfectly with the Axpert inverters Thank you very much
June 22, 20224 yr Inverters supported by Solar Assistant >> https://solar-assistant.io/#inverters The software is great and gives you a whole lot more in terms of data for use cases such as automation etc.
June 22, 20224 yr Author 23 minutes ago, mzezman said: Inverters supported by Solar Assistant >> https://solar-assistant.io/#inverters The software is great and gives you a whole lot more in terms of data for use cases such as automation etc. Thank you very much
