June 25, 20224 yr Hi my inverter is running a few panels and a Weco battery. However it continuously discharges to 98% when not needed and runs off grid at the same time how do I change this setting that it does not discharge when not needed
June 25, 20224 yr 53 minutes ago, Sean247 said: Hi my inverter is running a few panels and a Weco battery. However it continuously discharges to 98% when not needed and runs off grid at the same time how do I change this setting that it does not discharge when not needed Switch it off. All inverters ready to provide 220V will have a standing load and ready for action. Some as high as 2A from the battery. Over 24hrs it add up quite a bit for doing no real work.
June 25, 20224 yr Author If I switch the battery off then it defeats the object of having it foe loadshedding purposes and also being automated I will have to turn the battery on each time to use during load shedding and charging times there should be a setting on the deye inverter to sort this issue?
