Deye 8Kw Battery Max Charge
Good Day
I need some assistance. I have a Deye 8Kw hybrid inverter with 4 x Pylontech 3000 batteries. What can I set the max charging current Amps to the batteries. I know the spec sheets shows 37A for single battery but according to me it is a 4 battery bank that means it can be set to 4 x 37A = 148 minus 1 becasue the inverter will dist it between the 4 battery to bring it to 37A per battery....Is this statement correct.
Currently it is set at 50A...It it is taking the whole day to charge even if battery bank is only discharge to 50%. See attached
