July 6, 20223 yr Hi there Can someone help me in getting the latest firmware installed on my sol-i-ax-5.rm. I also have a pylontech lithium battery and a axpert modbus communication box that needs to be installed and have no glue how.
July 8, 20223 yr On 2022/07/07 at 3:27 AM, Mornelouw said: my sol-i-ax-5.rm. That's a rack mounted Axpert King. It has different firmware to all the other Kings (since it has a small, presumably old-style non0removable display), and doesn't seem to be a very popular model, at least with home users. It may be popular with commercial users, but they don't tend to post on this forum. The only rack mount firmware I have is fairly old: 74.10 main [ edit: I can't find that any more, and it turns out what I thought was Axpert King rack firmware was not ], and I seem to have a display firmware for it as well: 15.04. PM me if either of those is useful to you. NOTE: the 74.xx firmware number range is used by at least 3 incompatible models [ edit: now only 2,and one of those is from ~2016 ], so don't grab any 74.xx firmware that you find on the interwebs. Edited August 15, 20223 yr by Coulomb
August 14, 20223 yr Author Can you send me the firmware you have. Currently the firmware on my unit after uodated by mustek my raspberry pi do not read the inverters info it has 7508 on
August 15, 20223 yr On 2022/08/14 at 11:37 PM, Mornelouw said: Can you send me the firmware you have. PM'd.
