July 8, 20224 yr Morning all. Hope this is appropriate. I have had a predictably (in hind sight) bad experience with a fly by night night installer. He installed a 5Kkw Sunsynk and thanks n the process (through following this forum) I realised he was clueless so we parted ways. I have managed to fix most of his mistakes (CT coil around battery feed in inverter, badly scuffed cables, no Earth Neutral relay bond) but would really like a pro to make some final changes (move oven feed to main (non essential) DB, add another circuit to UPS circuit circuit in house DB). Most importantly I’d like someone competent to please double check installation and give me a CoC. Is there anybody highly recommended in the Jhb North area?
July 8, 20224 yr 42 minutes ago, rehcram said: Morning all. Hope this is appropriate. I have had a predictably (in hind sight) bad experience with a fly by night night installer. He installed a 5Kkw Sunsynk and thanks n the process (through following this forum) I realised he was clueless so we parted ways. I have managed to fix most of his mistakes (CT coil around battery feed in inverter, badly scuffed cables, no Earth Neutral relay bond) but would really like a pro to make some final changes (move oven feed to main (non essential) DB, add another circuit to UPS circuit circuit in house DB). Most importantly I’d like someone competent to please double check installation and give me a CoC. Is there anybody highly recommended in the Jhb North area? Read on this section and you will find a few posting here. Renewable Energy Solar Power Starting out with solar questions!
July 8, 20224 yr Hi Rehcram I highly recommend the guy who did my solar installation. John Thacker from Solar Brilliance came highly recommended to me from other people on my estate and he did not disappoint. He installed a 8kW SunSynk inverter, 14,8kW of Greenrich batteries, and 9kWp of solar panels at my house. You can contact him on 084 485 6868 or just look up Solar brilliance. He's also based in Jhb North. My installation was in Centurion. Alastair
July 8, 20224 yr Hi Rehcram. I just had a Sunsynk 5kW Inverter with 7.4kW BSL battery set up by Adriaan Rossouw from NuEco power. Incredible service and workmanship. Highly recommend - +27 83 651 5473
