July 15, 20223 yr Hi all, Happy Friday... New to this, and just had a LuxPower SNA5000 inverter installed, with currently 2x US3000C batteries, with another 2 on the way, so will have "14kW" capacity. So far, loving it, and it has made a massive difference to pure convenience during all the loadshedding, and not having to manually switch on the noisy and not so frugal generator, and manually messing with the DB board everytime. Also quite like the visibility it provides of consumption and battery usage, etc. Now I am keen to move on to adding Solar Panels, so I can at least get some relief on the monthly power bill...! I am considering getting 8 Canadian Solar 450W half cell mono perc panels, and attaching this to one of the MPPT inputs in a single string for now. That leaves some more options to grow on the second string at some point in the future. This seems to be within the 3200W and 13A capacity required per MPPT on the Inverter. Just checking that there are no suggestions for a more efficient or effective set-up considering my set-up? Many thanks for your suggestions in advance! Pete
July 26, 20223 yr Author Hi all... A quick update... for those that may be interested and find it useful... I have now added some Solar Panels. 9 x 545W Canadian Solar panels. These have been added as a single string, but connected into both MPPT's using the appropriate setting allowing for this. Now I will start checking what my peak power generating capacity is using this set-up. Holding thumbs! Still loving the LuxPower and Pylontech set-up... Pete
July 26, 20223 yr Hi Pete Did you bridge the 2 MPPTs, I am looking to run 5x 470 watt panels in series on each string.
July 26, 20223 yr Author Hi Zulfi! As I understood it - my panels are all on a single string, and then the last part before the inverter is effectively bridged, so with the two inputs into the MPPT's. I am not sure whether it would have been better to just have two separate strings (as you are contemplating), or whether the current configuration is better - but thought I would give this a go. I could still add a further 3 panels at the end of this string, without changing anything on the inverter end (apparently). Cheers! Pete
August 12, 20223 yr Author Hi, Another quick update... with the current setup at the moment I am seeing around 10kWh of solar production per day (to meet the demand during solar hours). I have moved my pool pump to the part of the DB board that is now covered by solar, as I was only seeing around 6kWh initially. I have noticed some shading that is causing a bit of degradation at some parts of the day, which then relies on grid to make up a little of the difference - so will be making a plan to chop down a little of the higher trees/palms in the way, and will see what this does. So far still very happy!
August 12, 20223 yr On 2022/07/26 at 4:30 PM, PeteV said: I am not sure whether it would have been better to just have two separate strings It would be the ideal setup. Two strings into the two MPPTs. That also makes even better sense if the two strings are not facing the same direction.
