Growatt lithium battery protocol
So i have a growatt spf5000tl-hvm and 2 growatt hope3.3l-c1 batteries...but when i select Li in setting 5 it takes me to a bms protocol setting which you dont find anywhere....does anyone have an idea which protocol to select
Hi Romeo,
Please see attached setup instructions,
I have the same batteries and a Growatt inverter, not very happy with the batteries as the keep giving allot of issues with coms and the system turning off completely at random times. What is your experience?
  • 9 months later...
Please give update an how well the growatt communicates with the battery as a friend has an 5kw growatt and am-2  51v 5.5kw Hubble battery on protocol 52
In the beginning everything worked great but after 2 week it would not charge passed 92% and getting worse so we set battery type to  user and run it from volts for 2 days to calibrate the setup , after 2 month the battery was not last longer than an hour of load shedding but was showing 99% full when charged but volts were 44v so battery was flat .
Best solution was to disconnect the communication cable and change battery setting to use and run it from volts only . Working great .
He want to get anothere battery but if there is issues with Hubble growatt compatibility it's not worth buying anothere Hubble .
it will be nice if your combination works
But it sound as if there is also issue with that combination from Jorams post
