Communication connection 3x PIP5048MK with pylontech batteries
Hello, I would like advice on connecting the communication of the inverter and pylontech batteries.
I use 3 inverters in a parallel system where each inverter has its own phase and the inverters are connected via parallel cards, everything works, the inverters know about each other and communicate, but now I need to connect the inverters via a cable to pylontech, (the cable is connected to the first inverter and the Pylontech master module ) communication only works with the converter to which the cable from the batteries is connected and the other 2 report error 61. How should the system be activated in this connection so that it works? Has anyone solved it?
The converters have a built-in protocol for pylontech...
