September 11, 20223 yr Hi, new to the forum here, looking for advice and info on the Soltaro inverter. I have been told by our local UK support office that this inverter only works with the soltaro battery. I have made my own 48v battery using reclaimed nissan leaf cells, in a 3p14s configuration. I have a DIYBMS system monitoring the battery and this has canbus capability I am looking to get info of the canbus data the inverter requires to operate, hopefully thn i can input that canbus data into my bms abd get the inverter to operate with my battery. After all, all the inverter shold need is a high and low voltage operating parameter, my bms will control the rest. Has anyone done any work with these inverters reverse engineeting them to capture this info Thanks Anthony
