Sunsynk SSLB1 batteries - Max charge/discharge current?
Hi, please can I have your advice. I have 2 x 5k Sunsynk SSLB1 batteries along with 2 x 80 amp fuses. My inverter is the Sunsynk 8k (SG01LP1-EU).
In the Battery Setup page, what is the maximum recommended current I can set for charge & discharge? For example, in the evenings I'd like the batteries to supply the load, eg cooker, kettle, etc without the grid kicking in.
[On the battery spec I see the Voltage is 48V and the max charge/discharge(5 min) is 4,800W (per battery). The max charge/discharge current on the inverter is 190amps].
Thanks for your help.
