October 9, 20223 yr Hi Esteemed Members I am a newbie here looking for a bit of guidance, I hope to learn from you all. I am in a three bedroom flat in a complex, looking to install a backup system to run my house during load-shedding. I am looking to install a basic system that will run my lights and a few plug points to run the TV, Soundbar, Wifi + Router, External Monitor when working usually during the day - TV will be off mostly when this is on - and possibly charge the laptop here and there. Basically a very small load as kitchen and everything else will be off. I estimate my load to be about 350W. I don't want a plug and play solution as I want to run the lights as if no load-shedding has happened. I also cant install any solar panels as I am in a complex. I am also keen to go Lithium for longer battery lifespan. This is where I need help I am thinking of getting a 24V, 3KwH inverter and a lithium battery pack for this. I have not clue as to which battery to buy nor which inverter. I am looking for a cost effective solution and would appreciate any recommendations from the knowledgeable members. I look forward to the recommendations. Edited October 9, 20223 yr by Eishkom
October 10, 20223 yr This is just my suggestion and I'm not an expert Please read my experience with a 24v system here I don't think to such a large inverter will give you any benefit if you are only using 350w, so save some money and stick to a 1kw system. I would suggest this combo of inverter and battery (I am only using sustainable links because I like that the website has alot of products and gives info of the products, once you have made a decision you can shop around and get better prices) Reason for that combo is the inverter has a max output of 1,2kW. Just that extra 200W for extra piece of mind. The battery has a 1C rating, so can discharge at the max the inverter can handle. Also 1,5kWh battery @ 350W discharge should give you 4-5 of power. If not you can have 4 batteries in parallel.
October 11, 20223 yr 12 hours ago, sjp100 said: This is just my suggestion and I'm not an expert Please read my experience with a 24v system here I don't think to such a large inverter will give you any benefit if you are only using 350w, so save some money and stick to a 1kw system. I would suggest this combo of inverter and battery (I am only using sustainable links because I like that the website has alot of products and gives info of the products, once you have made a decision you can shop around and get better prices) Reason for that combo is the inverter has a max output of 1,2kW. Just that extra 200W for extra piece of mind. The battery has a 1C rating, so can discharge at the max the inverter can handle. Also 1,5kWh battery @ 350W discharge should give you 4-5 of power. If not you can have 4 batteries in parallel. Very good advice. I installed a similar system and it works perfectly. TV and lights stay on, makes load shedding much less annoying.
