October 10, 20223 yr Hi As I understant it Riot and Cloudlink is the same thing. What benefits are there to getting the Cloudlink over and above everything that can be done and seen on the Sunsync Logger app? Assuming that Sunsync and Hubble have their independent ways of communicating.
October 10, 20223 yr The only advantage of the RIOT is that your battery can be remotely monitored and Hubble can perform remote actions like firmware upgrades. You can access pretty much the same data from the BMS via Solar Assistant as well.
October 10, 20223 yr 1 hour ago, Rogan said: But remote monitoring can be done with the Sunsynk logger? Not so? Remote monitoring of the inverter yes. Detailed battery data may require add-ons such as Riot
October 10, 20223 yr 1 hour ago, Rogan said: Detailed data such as? And thanks by the way. I don't have one myself so perhaps the Hubble+RIOT owners can chime in but I believe you can see the voltage for each cell as well as any errors etc on the battery
