June 30, 20179 yr hi! our axpert is set to charge the batteries from grid if there is no sun available [sol, setting 1]. but at about 03:00, the batteries are fully charged from the grid and i would like for them to at that stage [read time] supply whatever needs to be running in the house. this should continue until they have either reached their lowest set charge level [voltage point back, at this stage 46v, setting 12] or the sun takes over. such a setting will save grid consumption. i monitor the present setup with icc but have no bwv702 installed yet. yours in Christ gabriel
