Luxpower
13 hours ago, Roadrunner said:
Hi guys luxpower just shuts down for 20 seconds or so snd comes back online.E/L not tripping seems to be doing it with and without utility.Any ideas
Have you perhaps checked what the battery voltage is when it shuts down and under what load?
The battery Charge is still fine +_ 60% only happens when utility is off.. I have noticed only battery comminication failure from time to time for 5 min at a time and some times on the log it displays eps over load these do not happen at the same time, PS have tried it in paralel and single.
My config 2x dyness 48100 2 x Luxpower 5KW hybrid.
When this happens the load is +_ 300-600w per inverter.
I am considering adding another Battery, Would this help?
The communication Failure is a bit concerning also Causes reboots.
Drops from 60% to 0 and the to 59% on the history data.
I have swapped the Com cables issue remains. I still want to try and swap master and slave on the battery side.
