October 27, 20223 yr Quick question. No Riot / Cloudlink. For full comms I only need a CAN cable connection? With this I will be able to monitor battery via Sunsync app. Is this correct? Is the CAN BUS cable a special cable? Meaning I can not use a normal LAN cable? Thanks
October 27, 20223 yr Check the pin outs on the Hubble website. https://www.hubblelithium.co.za/sunsynk
November 1, 20223 yr Author SYC helped me. Bottom line is that a normal LAN cable can be used between Hubble and Sunsync. Dip switch 1 on.
November 1, 20223 yr I have a client with 2 x 8.7Kwh felicity batteries connected to a 12kw 3 phase Deye inverter; when I connect the communication cable, the inverter shows a W31 error/ warning; what could be my problem?
November 1, 20223 yr 4 hours ago, Milton said: inverter shows a W31 error/ warning and if you disconnect the comms cable the inverter operates normally? Have you checked the pinouts for the inverter and battery ?
November 2, 20223 yr I used the cable supplied with the battery and it is marked (Deye, Sunsynk,etc.) on the inverter side.
