November 10, 20223 yr Hi, I am busy installing an outdoor (waterproof) wall plug box for my water pump. I am going to be connecting it to my inverter circuit. Can this be connected to a normal circuit breaker or do I need a main/isolator switch? Edited November 10, 20223 yr by ultimz
November 11, 20223 yr If it came with a 3 pin plug you can install a normal plug outlet. I’ve done it this way. Test the plug to ensure it trips the rcd. Do you refer to a booster pump?
