December 13, 20223 yr Good day need help, at the beginning of the system installations the installer said that the system will always pull a bit form the Grid but for the last thew days no power is pulled from the Grid not even a little bit what can the issue be an how can I sort it because my installer is no help
December 13, 20223 yr When you took this screenahot was there loadshedding / a fault in your area? Can you take a picture of your inverter overview screen, its the one that shows grid, pv, battery etc
