January 7, 20233 yr I have two in parallel. I'm astonished to see how well they split the work. In this dashboard one can clearly see that there is enough PV to supply the house, so they are basically idling, however, looks like one is basically " a sleep " the other is supplying a bit of current to float the battery. Also, one can see if there is a demand for more load, they share the work.
