January 12, 20233 yr Hi Everyone, I am running a Greenrich UP5000 with a Kodak OG 7.2kw. Two questions? 1. Is there a specific RS485 cable I need to use? I currently only have the pylontech one that came with the inverter. Note: I have solar assistant, but need to get the correct cable for the battery before I can move from "Inverter values". 2. What are the optimal voltage settings for the battery? I currently have it set as below, but it seems to not keep its charge at 100. I assume my voltages are too low? Shutdown battery voltage: 46.0 V To grid battery voltage: 48.0 V Back to battery voltage: 52.0 V Battery float charge voltage: 55.4 V Battery absorption charge voltage: 57.0 V Max charge current: 40 A Max grid charge current: 20 A Edited January 12, 20233 yr by Gustav du Plessis
