Posted January 12, 20232 yr Hello, I have an installation with 2 DEYE hybrid inverters 3p-12 kW. Everything works normally, but I have a consumption of 10% of the power of the load which comes from of grid. Do you know how I can reset this consumption. see attached the configuration.
January 12, 20232 yr 48 minutes ago, Pierre-loiret said: Hello, I have an installation with 2 DEYE hybrid inverters 3p-12 kW. Everything works normally, but I have a consumption of 10% of the power of the load which comes from of grid. Do you know how I can reset this consumption. see attached the configuration. Are you not exporting to the grid and it is measured as consumption. Zero export to CT is not ticked.
