Water Chiller?
I'm in the process of building an ice bath (don't ask). Essentially a 300L water tank, which I need to chill to between 4 and 10 degrees C.
I've looked around SA but cant seem to find anything which sufficiently chill the water, and at the same time pump water from/into the bath at the same time (closed loop system).
Not sure if anybody has any ideas or solutions around this?
A couple of years ago when I still worked at a steel mill, we used closed loop water chillers (made by Daiken if I remember correctly) to cool lazer heads and measuring equipment. It was basically a closed loop water system where there were "aircon" tubes inside the cold water storage vessel.
I don't know what you want to cool, but what about a vortex air panel cooler? You only need a dry compressed air supply.
