Solar panel double checking on Kodak OG 3.24
Hi all.
Starting my reseach on installing some panels with my Kodak OG3,24. For reference here is the PV page from the manual.
So I was considering 4 to 7 Canadian solar 545w panels all in series with a 25A DC fuse connected just before the inverter. This should put me in the voltage and wattage range. I just need to know about the grounding. The manual stated no grounding, but the panels have a dedicated spot for grounding. Do I use different panels that don't require grounding (if there is such a thing) or do I just not ground the CS 545 panels.
TIA
Edited by sjp100
  • sjp100 changed the title to Solar panel double checking on Kodak OG 3.24
