Sunpolo inverter data connection to CFE Battery
Good day
I have a SAKO SUNPOLO inverter connected to a CFE  510s battery. I am struggling with the communication between the inverter and battery because I am not sure how the layout of the wires in the RJ 45 plug should be etc. Can anybody maybe assist me?
Kind regards
Does your Sunpolo have a Lithium mode under Program 05? (The 5kw models don't afaik)
I ask because the Manual I find only specifies AGM/Flooded and User-defined which would make comms likely redundant
Or do you have the newer 6/8Kw model?
Edited by PsyWulf
