February 16, 20233 yr I see lots of installations with DC and AC lines in the same trunking. How is this done? If in the same trunking must you use conduit to seperate the cables. Either hard or flexible conduit?
February 17, 20233 yr You get trunking that has a devider in the middel or you can use n smaller trunking inside the larger one.
