March 7, 20233 yr Hi, I got a 8kw Sunsynk Inverter installed, but if zero export is selected, so that we power the non-essential load also from solar/battery if eskom is on, the reading on the inverter go hywire. Getting zero load figures and pv figures also go up and down and grid go to negative. Sure this is not right. Is this a problem with the ct install or other settings that is wrong?
March 7, 20233 yr 36 minutes ago, Anton vD said: Hi, I got a 8kw Sunsynk Inverter installed, but if zero export is selected, so that we power the non-essential load also from solar/battery if eskom is on, the reading on the inverter go hywire. Getting zero load figures and pv figures also go up and down and grid go to negative. Sure this is not right. Is this a problem with the ct install or other settings that is wrong? Plain answer is the negative CT reading when drawing from the grid is wrong direction. This is the easy test. Other things we leave to the guys in the know. Edited March 7, 20233 yr by Scorp007
