Goodwe Hybrid Inverter configurion
Hi all, I am new here.
I had a solar plant installed last week with a Goodwe ET Series hybrid inverter, GW10K-ET, and a BYD HVL battery. It works very well in general mode but I can't figure out the Eco Mode.
I would like to charge the battery from the grid at night (we have very low cost at night) to ensure that I have cheep power during the day even in bad weather. The battery however does not charge during the night. I am using the PVMaster app (SEMS Portal app will not allow me to chose Eco Mode)
I have attached screen shots of my settings. Can anyone see what I am doing wrong?
Best regards
Jesper
image.thumb.png.ac88086603b8e8f7daf905a114e01f72.pngIMG_4728.thumb.PNG.f53b505d308d46c95cc764e48655f33d.PNGIMG_4729.thumb.PNG.5e18281c1e783838fae5df448f1d8405.PNGIMG_4730.thumb.PNG.1e9d7124e961a3ef527d0e0a512cf4d2.PNGIMG_4731.thumb.PNG.9d1de753f10eaf22236d130a035c6099.PNGIMG_4732.thumb.PNG.7fe92d41354174a400592029bc08e1c4.PNG
It appears that you are charging at 1% of rated power. "Rated power" is whatever your inverter is rated at. So if you have a 10kW inverter, you are charging at 100W. I suggest you increase that quite a lot, but not to a point where it's going to make the battery unhappy.
I can't assist you with the discharge function within Eco mode. I have never used that, and I'm not sure how it works.
Edited by Bobster.
