March 30, 20233 yr I have been through the Axpert Manual to see where i can change the max solar charge settings, which is set at 20A, but when it starts charging when solar is ample, it exceeds that 20A setting, and goes all the way to 30A at times.
March 30, 20233 yr Hi Andre. If your battery BMS is connected to your inverter it can change charging current on the inverter. Maybe this is what is happening here?
March 30, 20233 yr Author 1 hour ago, Jacques Ester said: Hi Andre. If your battery BMS is connected to your inverter it can change charging current on the inverter. Maybe this is what is happening here? Hi Jacques i also have the feeling that this is the case, however i want to know if this is normal/expected behavior
March 30, 20233 yr The Battery BMS knows what it wants. Just Leave it do what is required. Mine is currently asking for 110A charge even though it is only charging at 50A. This will change as the batteries fully charge.
March 30, 20233 yr Author 7 minutes ago, Jacques Ester said: The Battery BMS knows what it wants. Just Leave it do what is required. Mine is currently asking for 110A charge even though it is only charging at 50A. This will change as the batteries fully charge. Thank you Jacques, i am happy to leave it alone then 😁
