April 12, 20233 yr I have an RCT-AXMK4-5.6K-48V SOLAR INVERTER. Can I use a SUNSYNC 48 VOLT LITHIUM BATTERY with this inverter?
April 12, 20233 yr 1 hour ago, Rishi said: I have an RCT-AXMK4-5.6K-48V SOLAR INVERTER. Can I use a SUNSYNC 48 VOLT LITHIUM BATTERY with this inverter? In terms of the Lithium chemistry, yes, but you will want to make sure that the BMS protocol is ccompatible with your Axpert. The only compatible protocol for the Axpert will probably be Pylontech RS485 (not canbusl, but you must ask the suupllier wether the SS battery supports this protocol. Of course you can do away with BMS comms altogether, but you will have to check wether this will void the battery warranty.
