Connecting
Hi all. I have a 5kw sunsynk inverter, two 4.8kw lithium batteries and 10 panels(9 connected only). The batteries charge up full but around lunch time. Can I connect my tester onto the system so that the sun power can heat up the water. Does this connect to the aux port and how is it done. Had a few installers out over the years and every single one, says the previous guy did it wrong so I now have a natural doubt about these installers.
By tester do you mean geyser / water heater? Yes you can connect it up to Aux if you wish. You could also leave it on non-essentials and if the CT coil has been installed properly your inverter can push the excess sun to it
Which area are you in, we can suggest reputable installers
