April 23, 20233 yr I have the Growatt 5000eS with a 5kva Elithium battery, at night the battery will discharge to 75% and not charge until the morning when there is Solar to fill up the Battery. Is there a setting that stops the utility to charge the battery to 100%? Settings 01 - SUB 03 - UPS 05 - USE 14 - CS0
April 23, 20233 yr 22 minutes ago, Gema said: I have the Growatt 5000eS with a 5kva Elithium battery, at night the battery will discharge to 75% and not charge until the morning when there is Solar to fill up the Battery. Is there a setting that stops the utility to charge the battery to 100%? Settings 01 - SUB 03 - UPS 05 - USE 14 - CS0 Setting 14 at OSO means charge only from solar if Growatt are using the same as Axpert. Edited April 23, 20233 yr by Scorp007
April 23, 20233 yr 2 hours ago, Gema said: I am sorry i made a mistake, Setting 14 is SNU. OSO is still what you must select.
