One or two fused disconnects to Parallel 5kw Sunsynk inverters
I have seen examples of both one and two disconnects. My understanding is that you are supposed to break the 48V DC to both inverters at the same time.
Example
4 x rack-mount batteries connected to a common bus-bar, fused before the bus-bar (and each battery has a built in breaker 120A)
Do I now need two Keto1 125A fused disconnects, one to each inverter?  Or do I use one 250A and from there run battery cables to the two inverters?
Thanks for your input, much appreciated.
