Solarix Sacolar 5KW
Recently got 2 of these
https://www.esquireshop.com/ProductDescription.aspx?id=8627607
Don't let the descriptions on the web fool you,these are NOT Axpert types,they are actually Growatt SPF 5000 ES -alikes
Solarassistant also handles them as such
https://solar-assistant.io/help/growatt/spf-range
Picked them up at 12k a pop,so not bad compared to the Retail on Growatt's units
Specs below:
Features
• 5.0KVA Pure Sine Wave 48VDC Hybrid Inverter
• Continuous: 5kW / 5 kVA Max Watt Output
• High Voltage Built-In 100A MPPT Solar Charge Controller
• Voltage: 230V AC and Battery Voltage: 48VDC
• PV Maximum input current: 20A
• MPPT Voltage range: 120 to 430 VDC
• Can Be Set: Solar First, Grid First, Solar & Grid, Solar Only
• Solar Only: 100A (Maximum)
• Grid Only: Up To 80A
• Combination Solar and Grid: Up To 140A
• Peak Efficiency: 93%
• Overload And Short Circuit Protection
• Programmable Supply Priority For PV ,Battery Or Grid
• CAN & RS485 Port For BMS Communication
• Communication with LiFePO4 Batteries Via RS485 Port.
Firmware version
067.01
Secondary firmware version
068.01
I am yet to test the BMS compatibility as we had a loadshed coming up so I set the Hubbles to USR
These are full-hybrid looks like,i've tested blending Solar/Battery and Solar/Util
Edited by PsyWulf
  • 3 months later...
