May 17, 20233 yr Dears , can you suggest a replacement for Narada BMS SHINWA lM-M01A V1.5 with other brand ?
May 18, 20233 yr 5 hours ago, basemfutenh said: Dears , can you suggest a replacement for Narada BMS SHINWA lM-M01A V1.5 with other brand ? Hi, @Steve87 has been successfull with retrofit of JBD BMS for wide range of LifePO4 batteries. He can also provide additional controller to support Pylon canbus and LIB RS485, should BMS compatibility be required for mainstream inverters eg SunSynk, Axpert.
